W113 Pagoda SL Group => Electrical and Instruments => Topic started by: natenate on March 05, 2012, 17:20:24
Title: spark plug leads
Post by: natenate on March 05, 2012, 17:20:24
Hi im trying to buy a set of spark plugs leads for my 1967 230sl. somebody told me that euro parts do a beru replacement. but when i phoned them and gave them my reg number they can not find the part number. does anyone have any idea what the part number is??
regards
Nathan
Title: Re: spark plug leads
Post by: Benz Dr. on March 05, 2012, 23:49:42
A proper Beru set is available. I can't tell you what the part number is and it's very likely there isn't a MB part number for this set.
Most of the Bosch replacement sets I've seen have been wrong on several fronts:
carbon core coil wire
resistors on the wire ends
improper spark plug terminals with 90 degree ends
2K or even 5K spark plug terminals
Proper 230SL set should have no resistors on wire ends except for spark plug terminals with 1K ohms.
Spark plug terminals are bakelite without metal shields.
All spark plug terminals are straight for 113 style engines.
No carbon core wires.
 About $65.00 for the set if I remember correrctly.
Post by: franjo_66 on March 06, 2012, 03:18:35
I just bought a proper OEM style set made by Karlyn for my 230SL. Only cost me $33 from www.autohausaz.com
Link to the product details as follows:
http://www.autohausaz.com/search/product.aspx?sid=wflzzd455ay1ov3eop0hal55&makeid=800016@Mercedes&modelid=1342729@230SL&year=1965&cid=25@Ignition Parts&gid=7228@Spark Plug Wire Set
I bought these for all the reasons listed by Dan (ie proper coil wire not carbon, no resistors, etc). These plus the 123 Distributor and red Bosch coil have made a profound difference to the engine performance.
Franjo
Post by: Raymond on March 18, 2012, 22:32:18
Franjo,
What color are the spark plug ends and do they appear to twist onto the cable?
Post by: stickandrudderman on March 19, 2012, 07:55:13
The PN for the set is 1301501318 and was available quite recently.
Failing that you could try magnecor:
http://www.magnecor.co.uk/
Post by: franjo_66 on March 19, 2012, 10:17:50
Ray, my car is in the workshop waiting to get a rebuilt hydraulic coupling for the auto.
From memory I think the ends were black. When I get her back I can check the ends, etc and let you know.
Reds
Franjo
