W113 Pagoda SL Group => General Discussion => Topic started by: n/a on June 01, 2004, 22:17:16
Hi everyone
I'd like to use an engine stand to mount a 230 SL motor for longer term storage. Putting the motor on seems pretty straightforward but any tips or advice from other listers would be much appreciated.
Thanks, Mark
1965 230 SL light blue, auto, RHD
All of the engine stands I've used have adjustable and movable fingers (or arms) which are set up to be bolted to the read of the engine, using the existing transmission bell housing bolt holes. Its as straignt forward as it gets. Be sure your stand has large casters for easy manuvering of the whole thing when you want to move it.
The biggest trick is holding the engine up to the stand with one arm, while trying to thread in the bolts thru the stand fingers, into the rear of the engine.
...just kidding [;-)]. I assume you'll use an engine hoist or similar to hold the engine while you position it and the stand together.
1971 280SL US Automatic
