W113 Pagoda SL Group => General Discussion => Topic started by: blairwag on May 31, 2004, 20:26:58
Title: Filling antifreeze/coolant
Post by: blairwag on May 31, 2004, 20:26:58
What's the trick?  How do I fill the system, and not end up with a ton of air in the upper half of the radiator? I have filled the reservoir bottle ever so slowly. I do so with that little hose that goes from the radiator to the reservoir tank disconnected, so the radiator can escape the air. But, the reservoir bottle fills to the top and overflows before the radiator is filled. I can tell there's no coolant in the upper radiator hose, too.
What I've done thus far is:
Disconnect upper radiator hose from thermostat housing, and poured coolant down it until coolant begins to seap out of the thermostat housing, then reconnect the hose.
Then, dribble water down into the radiator, through that little hose connector at the top passenger side of the radiator (vent tube connector), until the radiator is full.
But, there's got to be a better way?
Any advice?
1971 280SL US Automatic
Title: Re: Filling antifreeze/coolant
Post by: Tom on May 31, 2004, 22:09:03
William,
The old Yahoo site has information on this procedure:
http://f4.grp.yahoofs.com/v1/MPG7QPDsffS1TFQAcirJ41h9EwmVorCCggvGs-ttkC2oayz3dZ84RZP2d6fepT-y000t3IzBf5MvjB3uBDCo/How%20To%20Folder/How%20to%20back%20flush%20a%20w113.doc
Or see attached.
Hope this helps
Download Attachment: (http://images/icon_paperclip.gif) How to back flush a w113.doc (http://www.sl113.org/forums/uploaded/Tom/2004610452_How%20to%20back%20flush%20a%20w113.doc)
34.29 KB
Post by: blairwag on June 01, 2004, 07:13:49
Outstanding. Thank you!  I knew there had to be some hidden trick to it all.
Thanx, again, Tom.
