W113 Pagoda SL Group => Electrical and Instruments => Topic started by: JamesL on September 26, 2011, 19:04:19
Title: windscreen washer
Post by: JamesL on September 26, 2011, 19:04:19
Odd one...
If my screen wash bottle/bag is full, I get a decent spray and can clean the screen well enough
If the bottle/bag is not full, I get a trickle, lots of foam and not much else
It's been suggested that the pump maybe at fault but I am curious if anyone has had a similar problem and solved it!
Thanks all
Title: Re: windscreen washer
Post by: ricrose on September 26, 2011, 21:26:05
Hi Tosh
My limited hydraulic experience would suggest a hole in the suction pipe - perhaps a little below the full mark in the bag. As soon as the level reaches the hole it sucks some air and at that stage you get a reduced stream and froth. I would just check the pipe for a small hole just below the waterline.
Cheers
Richard
