W113 Pagoda SL Group => General Discussion => Topic started by: waqas on May 21, 2004, 12:50:42
Title: Strange vibration in first gear
Post by: waqas on May 21, 2004, 12:50:42
Greetings:
I recently purchased a 1965 230SL (manual transmission), and I'm slowly going down a list of repairs/issues. One perplexing problem is a strange vibration when driving off from stand-still (in first gear). It goes away after I get moving and release the clutch. This only appears from stand-still-- no problems when shifting to higher gears. I've been driving manuals since I was 13, so don't think that's the problem. The vibration is pretty strong-- as if the engine is fighting against it's mounts. Any ideas?
Thanks and kind regards,
1965 230 SL Euro, 4sp. man, dark green
Title: Re: Strange vibration in first gear
Post by: blairwag on May 21, 2004, 14:16:27
One possibility is clutch chatter. A situation caused by a warped surface of the clutch plate. The typical solution is to replace the clutch.
1971 280SL US Automatic
Post by: waqas on May 21, 2004, 20:53:54
If it were a warped clutch plate, would this not also occur when switching in other gears?
The "shuddering" only occurs from a stand-still in first gear. Strangely enough, it does not happen while reversing.
There's also a strange grinding noise from the transmission/drive-shaft area while driving, when I take my foot off the accelerator (any gear). I'm just now reading about all the grease nipples on this car (!), so I'll see if the grinding continues after I grease the main drive-shaft nipples. The transmission doesn't seem to be having any problems while shifting (as far as I can tell).
On a related note, when I changed the differential fluid, I found tiny metal slivers gleaming in my empty oil container. I'm guessing I'll need a differential rebuild or replacement sometime in the future :-(
I wonder if the grinding is from the differential?
Post by: hands_aus on May 22, 2004, 04:38:59
Hey waqas
If your engine mounts are old and tired you will have vibration of the internal rear view mirror and feel the vibrations throughout the car.
Similarly with the big rubber diff mount (accessible from within the boot) and the rear axle suspension rubbers too.
Worth a look.
Have a look here for the grease points
http://www.w111.net/html/abschmierplan.html
Bob (Brisbane,Australia)
Post by: Mike Hughes on May 22, 2004, 07:42:39
Even if the front engine mounts check out ok, be sure to check your transmission mount.  Bad ones on one of my other cars caused similar vibration problems in first and especially reverse.  Replacement cured the problem.
Post by: ja17 on May 23, 2004, 22:03:28
Hello waqas,
Also check the rubber flex disc at the drveshaft/transmission connection. The rubber disc should not be cracked or shreaded. Make sure all the bolts are tight and correctly installed.
Post by: waqas on May 24, 2004, 13:58:46
Thanks for all the advice. Just a quick note to let you folks know that I haven't had a chance to look at mounts or flex disc-- been working on getting my daily driver going again (I've a funny tale about how my '87 Honda's head gasket blew on the way to go see my pagoda for the first time-- I guess my old car got wind of my intentions and started acting up!) Spent all weekend removing the head and doing other assorted repairs. Will report back as soon as I get back to the 230sl again.
Incidentally, while driving the pagoda to work today, I noticed some shuddering/vibration at speeds over 80kph (unrelated to clutch). The tyres seem balanced, but steering showed slight pulling (alignment). I suspect the shuddering has something to do with the suspension, or even said engine mounts. Just some more data, in case you gurus start seeing a familiar pattern.
