W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Khurram Darugar on June 10, 2011, 11:13:52
Title: Disassemble Locking gas cap
Post by: Khurram Darugar on June 10, 2011, 11:13:52
Hi All,
I have lost the key to my locking gas cap.  Luckily the standard cap was on the car at the time.
I have got the locking tab off the rear which releases the spring and nut.
Now for the next bolt in the picture.  How does one get this off without damaging the locking assembly or exterior chrome.
And finally is it possible to have the barrel altered to match the ignition key?
Theoritcally the barrel should slide out after this?
Kay
Title: Re: Disassemble Locking gas cap
Post by: Peter van Es on June 10, 2011, 11:48:14
http://www.sl113.org/wiki/Fuel/LockingGasCap
Technical Manual... always look there first!
Post by: Khurram Darugar on June 10, 2011, 12:29:35
ok good point.
However im still stuck.  The tech manual refers to a small hole from where the lock is released.  However i have no hole on mine.  New pic attached.
Kay
Post by: sully on June 10, 2011, 19:56:46
Hi Kay,
I have two extra fuel cup that not had key and took them to lockal locksmith and he made new keys witouth openeing the cup only charged £5 for each key
thanks
Sully
Post by: 114015 on June 16, 2011, 22:25:59
Hi Kay,
It appears as if the late-style gas cap (one key fits all) cannot be deassembled like the earlier style (3 keys; door key unlocks gas-cap) as described in the factory workshop manual.
Had the same scenario with a very similar non-chromed sedan's gas cap.
Drilled little holes into the inner part similar to the ones of the early-style gas-cap. No successs. Does not come apart.
Try Sully's recommendation.
Post by: hands_aus on June 26, 2011, 20:30:06
Is the car one key does everything?
I worked on the other style cap but I have no experience with this one.
I see a fine gap between the inner and outer sections.
There might be a catch in there that needs to be released before it will separate.
I wonder if inserting a metal shim or something similar and moving it around the circumference will achieve something.
Post by: erickmarciano on October 06, 2011, 03:41:51
Any luck on opening these late gas caps I am in the same situation
Post by: 114015 on October 06, 2011, 21:05:59
Quote
Na,
did not attempt that yet.
Myself I am also reluctand to sacrifice one in order to find out - too valuable part ... better live with the locksmith's solution ... and perhaps the wrong additional key.
But I am afraid that is the only way to go. "We" (= someone) has to cut one of these to find out how the inner and outer parts are assembled. Must be slightly different (or simpler) from the earlier type. :-\
