W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: davids on March 16, 2011, 15:09:22
Title: engine surges
Post by: davids on March 16, 2011, 15:09:22
1971 280sl. 107,000 miles,had injection pump rebuilt about 6000 miles ago, had injectors checked at same time. car just started surging at high speed about 55mph and over under acceleration, can anyone tell me what to check?
Title: Re: engine surges
Post by: ja17 on March 16, 2011, 23:51:23
I assume you are describing an engine surging and not a high speed engine miss.
Standard tune up items should be checked first...........timing, distributor vacuum advance, fuel filter, fuel pressure and volume,  ignition points, spark plugs and wires, engine linkage set up.
If nothing shows up there, you could do a "split linkage CO test"  to determine if you may need an injection pump adjustment.
Lots of information on all these items already posted, but get back with us if you need more information or additional clarification of any of these items.
Keep us up to date.
Post by: davids on March 17, 2011, 20:03:22
wondering how you can tell if it is a high speed miss?
Post by: ja17 on March 18, 2011, 03:08:00
Here is my thoughts on the two................A" high speed miss"  feels like a cylinder or cylinders are  cutting in and out. It may be a kind of slight jerking feelingfrom the engine.  A "surging" engine is one which may be running smooth but speeds up or slows down while the accelerator pedal is constant.
Post by: davids on March 23, 2011, 15:29:19
Thanks for info.Put new plugs in runs perfect. Thanks
Post by: ja17 on March 24, 2011, 02:24:32
It's great when the cheap and simple items fix the problem !  Spark plugs are a good place to start.
