W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Rick007 on March 02, 2011, 00:00:42
Hello forum members,
Does anybody have any experience with the aluminum inserts that go into the front wheel arch ?
They are aftermarket and protect your inner wheel well ( headlight , fenderboxsection )
I have them installed on an other car of mine ( Volvo ) and it works really good .
So I got a set from SLS for the 113 but just can't get them into place . ......anyone ?
I have not had any experience with these, but would like to see a couple of pictures to better understand what you are typing about.
OK i mean they are basically large mudguards ...
Hi Rick,
What an excellent idea, do you have a part number as I can't seem to find them on the SLS web site.
Hi David ,
The number is : 288054 Satz Innenkotflügel R113 , Aluminium . € 142,80 incl. M.w.st ( VAT )
With some primer for Nonferrous Materials you could spray or paint them in your car colour .
Mine Is 180 ( silver ) so no need for that . The only problem is i may have to cut them to fit.
I know they must have a tight fit ( with air flowing from front to back ) but they don't exactly slide in easily , that's why i asked
forum-members if they had any experience with these things on our 113 . Fitting them on my Volvo was a breeze and they don't show on the outside .
Thanks Rick although I did purchase those panels and the rubbers, items 12 & 13, from SLS a couple of years ago and they were just the standard MB splash plates as per the graphic, are they now the parts in you're photos?
David ,
Yes i know those are the standard splash guards and seals that fit between footwel and fender , but as soon as you click on that item ( nr 12 )
you also see a third item which is the set of aluminium guards . The top one to be exact . And those are the items as on my pictures .
The company that made these was 'Lokari.de'
but the web address no longer works so maybe they
are no more.
Yes that's the brand-name , think SLS still have sets do .
Thanks Rick, I've now found them and will certainly be buying a set.
Manufacturer can be found at http://www.lokari.eu
I gather from another site that the fit is not the easiest and they secure via L shaped brackets that screw into your car. That said, the other site seems to prefer that to all the crud ending up in inaccessible places and causing unknown problems...
There are fitting instructions on the site in German ???
Thanks ,
I visited there site and now I know why it's such a tied fit .
They advice you to use a wax to act as lubricant that will ease the fitting .
They also state that the gap you should recon with acts as an sort of air vent , to prevent dirt and water being caught .
Like I stated earlier I have them on my Volvo p1800 , and after restauration ( it has a British manufactured body , sorry guys :) )
I thought it was a good solution . The total front body was totally gone , because water and sand collect es between fender and subframe , and that's proving to be an ideal rust-nest . Our Mercs have a similar construction so I think for us who don't live in California it's the thing to install ...
I also saw that they don't have them in stock right now .....takes 6 weeks .
Rick
It looks like they have nothing in stock at the moment in either ally (our cars) or plastic
http://www.ddk-online.com/phpBB2/viewtopic.php?t=3552&start=0 (http://www.ddk-online.com/phpBB2/viewtopic.php?t=3552&start=0)
http://www.ddk-online.com/phpBB2/viewtopic.php?t=27717&start=0 (http://www.ddk-online.com/phpBB2/viewtopic.php?t=27717&start=0)
Maybe they make them to order?
Naj
That was my guess. Wonder if they could use the 113 template to make pastic ones?
Thanks Tosh ,
Looks like the Porsch drivers are very enthusiastic about them as well, seems that at there cars its a rust prone spot as well.
Will take some pictures when i installed them .... May take 2 weeks do .
Hello All,
After complete restotation of my 280 sl 1970 (I changed the 2 front fenders and internal beam structure incl front end), I fitted these mud guards and they fit very very well.
They look like the ones on the pictures in this discussion.
Before to fit them I followed the instructions and spray some cavity lubricant inside the wheel arches. This lubricant is named "fluid film" and is made from lanolin (natural grease from sheep wool : no risk for environment nor rubber seal surrounding this guards).
As I already mentioned in another discussion on the forum, I will make one picture of those parts in place.
I did not have to modify them nor cut them to put them in place.
I just put in sandwich 2 rubber cylinder between the rear fixing screws that could maybe touch the fireboard (just up of the floor). I also replace the screws of the kit by S/S self tapping screws to avoid corrosion and electrolytic bridges between carbon steel and alunminium.
Each guard is fixed through 2 aluminium set squares (one front / one rear).
The maximum time for one side fitting is 1 hour - 1.5 hours depending of your know how in working under your car ;-))
Best regards.
Vincent R (France).
