W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: shimon zohar on February 21, 2011, 14:55:29
Title: automatic gearbox repair kit
Post by: shimon zohar on February 21, 2011, 14:55:29
hello
do you now if there a kit for repair automatic gearbox (rubber discs at...). ?
thanks.
 shimon zohar
Title: Re: automatic gearbox repair kit
Post by: jacovdw on February 24, 2011, 19:01:37
Hello Shimon,
I presume that you meant gasket kit when you said "rubber discs"?
Also, I'm not exactly sure what type of pagoda you have (230, 250 or 280SL), but a quick glance of the EPC shows no gasket kits available (as with later model automatic gearboxes).
Only the individual gaskets and seals are available and there are quite a lot of them.
Post by: 66andBlue on February 24, 2011, 22:53:35
A quick search with Google located this vendor who shows a Mercedes kit p/n 112-270-18-00 as suitable for a 280SL:
http://www.pelicanparts.com/catalog/shopcart/Z035/POR_Z035_Transm_pg1.htm
What transmission model do you have in your car?
Post by: nikopu on February 25, 2011, 10:27:59
Check out www.sls-hh-shop.de
They have a good gasket kit. They also can supply clutch disks. Beaware, that brake bands are no longer available. If needed, you'll have to have the original bands re-surfaced.
Post by: shimon zohar on March 01, 2011, 05:55:57
hi guys
thanks for the replay.
my car is 280 sl 1970. i look for the all things to rebuild the trans not only the gasket .
the rubber is for the inside of the trans. if some one order the kit ,parts ,act before can help.
i understand that the gear box ar the same for the all years and i can install 230 sl trans as well.
thanks
shimon
Post by: naniroma0 on February 17, 2013, 21:33:25
hello,
I've done the work to replace gaskets, seals and clutch discs and the lowest price was in the service MB,
