W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: dseretakis on June 10, 2010, 14:55:33
Title: Oll filter
Post by: dseretakis on June 10, 2010, 14:55:33
I have a few OEM Mercedes oil filters lying around.  I think but I'm not sure that they are for my pagoda. Part numberon box is A 000 180 00 09. Can anyone confirm if this is the correct filter for my 71 280SL?
Title: Re: Oll filter
Post by: mbzse on June 10, 2010, 15:44:42
Quote from: dseretakis
Part number on box is A 000 180 00 09. Can anyone confirm if this is the correct filter for my 71 280SL?
yes
Please ensure that the ring [(2) in diagram here] is present on your car
/Hans in Sweden
Post by: Naj ✝︎ on June 10, 2010, 16:34:59
Yes, thats the correct part  # for the Pagoda filter.
The seal ring pointed out by Hans is not a part of the filter kit.
It has to be purchased separately and does not need changing every time you replace the filter.
Have a look in the wiki for the seals that need changing periodically.
Post by: dseretakis on June 10, 2010, 16:43:06
Thank you all. I do recall the sealing ring from my last oil change. Thanks for the reminder.
