W113 Pagoda SL Group => Electrical and Instruments => Topic started by: sarasotasl on April 25, 2010, 16:29:32
Title: AC blower fan switch
Post by: sarasotasl on April 25, 2010, 16:29:32
My blower fan stays on low all the time.  The Hi - Med - Low works OK but will not turn off when it's in the off position.
Can this be repaired, or do I need to replace the blower switch?
Title: Re: AC blower fan switch
Post by: w113dude on April 26, 2010, 12:05:19
If the switch has not been used a lot this happens, Take out the switch out of dash and spray it with good quality electric contact cleaner & rotate the switch back and forth, This works for me every time. while it's out you can check to see if it works right by using a ohmmeter.
Post by: sarasotasl on April 26, 2010, 23:56:06
Thanks for the reply.  Will give this a try.
