W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: alfances on March 31, 2010, 10:25:52
Title: Fuel Unit Sender With External Float
Post by: alfances on March 31, 2010, 10:25:52
i have a problem on my  Fuel Sender Unit transmits.I try to look on internet to find a new sender unit with external float,but i find the later cylindrical sender unit with internal float.I don't know if the internal float unit will work and fit in my tank.
Anybody know or had this experience and explain if is possible?
i attached the address of the picture
http://www.sl113.org/wiki/Fuel/SenderUnit
If somebody can give me some suggestion were i can find the sender unit with external float i will be grateful.
Title: Re: FUEL UNIT SENDER WITH EXTERNAL FLOAT
Post by: scoot on March 31, 2010, 17:41:48
I salvage fuel senders from junked cars, disassemble, clean, test, get new cork gasket, and re-sell them.   Three times I have come across the early style like you have and never have I managed to get to function.  In contrast, I have been quite successful with the tube-style floats in terms of cleaning and getting them to work right.  I think it is a drop-in replacement but I'm not 100% sure.   If you want to buy one from me you can return it if it doesn't work for you...   See my post in the commercial forum.
Scott
Post by: Naj ✝︎ on April 02, 2010, 12:20:34
Scott
Check the table below the sender unit pictures in the wiki. The dash unit would also have to be replaced to use the later tube type sender.
The external float types were also commomly used in the early W 111 sedans, if that helps.
Post by: xcashewx on April 05, 2010, 02:38:42
the early 230's had a guage that is NOT compatible with the later cylindrical sender
Post by: Naj ✝︎ on April 05, 2010, 10:25:45
Seems like we've got two threads going on this one  ::)
http://www.sl113.org/forums/index.php?topic=12480.msg84502#msg84502
Post by: Peter van Es on April 05, 2010, 14:39:25
I've merged them to one topic now!
Post by: scoot on April 05, 2010, 17:58:42
Good to have the threads merged.  I did not know that they were not interchangable.  Very important info!  I guess I better keep trying to salvage the old style when I find them....
Post by: alfances on April 07, 2010, 07:28:21
Thank you very much for your answer,i was almost convinced to buy the cilyndrical float and try it.If someone have the old external float for sell i will be very happy.
