W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: johnm on February 03, 2010, 17:07:29
Title: Staples
Post by: johnm on February 03, 2010, 17:07:29
 Hi Folks.... I'm in the process of re-covering the two panels located just foward of each door and under the dash of my 280SL. In removing the old leather covering I find the staples have a barb of approx 1/8" to accomodate the thin panel. The smallest I've been able to locate here in Nova Scotia is a 1/4" barb in the local hardware stores. Is anyone aware of where I may be able  to source these along with the appropriate staple gun. OR is there a more effective method of fastening the leather to the panel without using staples? Thanks!
Title: Re: Staples
Post by: mdsalemi on February 03, 2010, 19:00:47
John,
Hey, could be worse!  You could be in Newfoundland... ;)
Anyway--you'll have to go mail order.  Try this chart first:
http://www.senco.com/pdf/catalog/st_chart.pdf
Then call Senco or find some sources that might be able to get the size you need.
http://www.stapleheadquarters.com/fine-wire-staples-fasco.html#medium
http://www.garysupholstery.com/products.html
Title: Re: Staples
Post by: menesesjesse on February 03, 2010, 19:32:16
John I used 3m spray glue and it worked great.  Get the heavyduty stuff and you should have no problems. Note of caution: keep it from getting on your hands because it is a pain to get off.
Jesse
Title: Re: Staples
Post by: Dave Gallon on February 04, 2010, 09:20:35
The short staples are commonly used in the upholstery industry. Find a commercial upholstery supply. I bought a box of 1,000. Of course, you will need a compatible staple gun; I purchased a relatively inexpensive pneumatic staple gut to make the job quick and easy.
