W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: rogerh113 on July 03, 2009, 22:15:10
Title: IP Oil level - measuring??
Post by: rogerh113 on July 03, 2009, 22:15:10
Is the Injection Pump oil level measured at the 'inserted' or 'screwed in' level??   The screw threads are about a half inch, and it makes a big difference if they are counted or not -  the current level is good if measured screwed in, or low if just measured at inserted level.
Regards -- Roger
Title: Re: IP Oil level - measuring??
Post by: jameshoward on July 03, 2009, 22:53:03
Screwed in level is the measurement to use.
Post by: rogerh113 on July 04, 2009, 00:13:30
Thanks - then it looks like the level is OK.
Regards -- Roger
