W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Neal on May 15, 2009, 03:38:14
Title: 250 turns over but just won't start
Post by: Neal on May 15, 2009, 03:38:14
The car which is normally difficult to start, won't catch and run. I can turn it over and it starts to bite and chug but will not run. We looked at the cold start and it works, all the plugs are clean, there is good spark and the fuel is running well. The fuel pump is only a year old and sounds great. What next before having it towed to the shop?
Title: Re: 250 turns over but just won't start
Post by: waqas on May 15, 2009, 14:01:45
Some random suggestions:
Post by: ja17 on May 15, 2009, 22:11:39
Add some more fuel to the fuel tank.  If you have sediment in the tank the car will starve for fuel when it gets down to about 1/2 tank of fuel.
Post by: Allenh on May 15, 2009, 22:52:25
For what its worth, If you have am M129 engine, some otheres too, the crankshaft markings for timing will probably br dual and about 30 degrees apart.  If you static timed it with the wrong set, you could find yourself where you are.  Ensure you are timed correctly.
Allen
