W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Largeowner on April 21, 2009, 00:41:01
Title: Distributor adjustment
Post by: Largeowner on April 21, 2009, 00:41:01
Hi Folks,
I have a 1967 230 SL.  Even though I run 93 octane in it, there is slight knocking when I accelerate hard.  The distributor is an 051 with the bolt and pointer for adjusting when using a "lower octane" fuel (early system).
  My question is: How does this adjustment work?  When I loosen the bolt, the pointer just moves freely and does not seem to be attached to anything.  I set the marker to 2 notches off of "F", but the knocking persists.
Large
Title: Re: Distributor adjustment
Post by: thelews on April 21, 2009, 01:30:32
You would first need to loosen the hex bolt holding the distributor in place.  Then the pointer gizmo might work, but it sounds like yours is not.  To correctly check and set the timing you should have good timing strobe light and tachometer.  You want to check it at idle, 1500, 3000 and 4000 rpm.  You need to check the manual for your proper specs.
Post by: jameshoward on April 21, 2009, 06:54:52
Large,
If you are going to set the timing to spec (start there and then adjust again if it doesn't sound right) then first check the dwell of the points on the 051. It's not complicated, but you will need a dwell meter. Many automotive amp meters have a dwell function, and they also tend to have an RPM function also. If you buy one with both functions you'll be able to do the job properly using a strobe gun. It's not a hard process at all, and very satisfying. There is a lot here on the site about such adjustments, and the Haynes manual has a pretty good section. The kit isn't expensive at all.
Of course, before doing the points, you might like to take a look at the linkage tour first to ensure that everything is set up properly if you haven't already done so, then a gross error check on the points gap (using a feeler gague), then check dwell, then do timing last. You can also check things like resistance in your spark plug leads and other fun things with the amp meter! (I found a problematic lead that way; wish I'd started with the leads as it would have saved me a lot of time).
If you don't have the haynes manual, or the BBB (both worth getting) let us know and I'll post the specs for dwell, etc.
JH
Post by: Largeowner on April 21, 2009, 14:40:39
I was hoping for a quick and easy fix for a very minor problem, but it is always better to "DO SOMETHING THE RIGHT WAY".  Looks like I am buying a dwell meter today!
Thanks for the replies!
Large
Post by: ja17 on April 22, 2009, 02:36:27
Hello Largeowner,
Make sure you are using high octane fuel.
Post by: Largeowner on May 06, 2009, 14:48:45
Hi again,
This reply is a bit delayed because I had to special order a Dwell Meter and Timing Light.
My Dwell is now set correctly to 39 (range 38 plus 2 minus 1).  However, a new problem has emerged...
When I set the timing to the correct 2deg BTDC (plus or minus 2), the warm idle RPM is a whopping 1500 RPM!  I can adjust the timing to bring the idle down to 800 RPM, but this retards the timing to 8deg ATDC.  I ran the car around the block at this setting and it REALLY seems to like it!  The hard-acceleration knocking is gone, and the engine pulls strong with no hesitation.
So, my new question is:  Is this a safe setting to use or am I risking calamity?  Do the members of this group recommend returning the timing to spec and dialing down the idle RPM instead...and if so, how do you do that?
Thanks again for all the answers,
Large
Post by: thelews on May 06, 2009, 14:54:11
Hi again,
Large
Did you disconnect the vacuum line to the distributor before timing?  Follow the plastic line from the distributor to where it connects on the passenger side and pull it off.  Then plug the hole where you pulled it off from.
I just reset my timing on the 250 SL and defer to the 3K -4500 rpm value, 30 degrees btdc.  After setting there it fell close to the values specified for idle and 1500.
Post by: Largeowner on May 06, 2009, 15:16:37
John,
The specs on this site say to keep the vacuum connected for all settings on the 051 distributor.  So that is what I did.
Large
Post by: Naj ✝︎ on May 06, 2009, 15:31:45
At idle, does connecting and disconnecting the vacuum line make any difference?
With vacuum disconnected, when you set the timing at 30 degrees btdc at 3k rpm, then your timing reading will be around 8 degrees btdc at idle. When you reconnect the vacuum, it should retard to atdc.
Have a look in the wiki to ensure you have a matching 'retard' throttle body with the vacuum line connecting below the 'throat'.
Post by: glenn on May 06, 2009, 15:35:05
Sounds like too much fuel.  Cut back CCW on the FIP knob(engine stopped).  You want 800 RPM with right amount of air to burn the minimum amount of gas necessary for 800 at correct timing.  Then cut back air 50 RPM to get 750 slightly rich.
   And rotating the distributor a couple degrees(to retard) should end the pinging.
Post by: thelews on May 06, 2009, 15:36:46
Not sure what you're reading, but with my 051 distributor, the specs are to disconnect the vacuum.  Leaving it connected would produce the type of issue you are having.  NAJ response agrees with my experience.
P.S.   Wiki is a nice thing, but I will always defer to the MB owner's manual and MB service/tech manuals
Post by: Naj ✝︎ on May 06, 2009, 15:43:06
On the vacuum retard system, its rather academic whether you disconnect the vacuum or not. As soon as you open the throttle, the vacuum falls away, and should not affect the advance at 3k rpm. Now, with vacuum advance, its a whole different matter.
Disconnecting/reconnecting the vacuum line does let you ensure that the vacuum retard is working.
P.S: I am glad this debate is taking place as we need to make the Tech Manual accurate and dependable.
Post by: thelews on May 06, 2009, 15:54:49
But, if his is working, and he's trying to set his timing at idle (which I wouldn't), then, ve gotta prrrroblem.  Otherwise, what you say is true and he can eliminate the issue on the 051 dist. by setting the timing at 3k-4500 rpm at 30 degrees.
Post by: Largeowner on May 06, 2009, 17:34:03
Dear All,
I just checked the distributor setting spec column out of the Tech Manual again to make sure that I had not goofed.  My car is a 1967 230 SL and has the cast iron distributor with the allen screw clamp.  It is marked JFUR6 and is an 051.  The vacuum enters at the front side of the distributor.
The tech manual says that this is a retard distributor, and the specs say to set timing with the vacuum attached (w).  I did not want to use the specs in the manual (green book) because it applies to the older vacuum advance distributors of the early 230 SLs.
I agree that setting the timing at 3000 RPM takes the vacuum issue away, but this is a "one man job" for me.  I was attempting to set it at idle, and check it at 3000 RPM.
Other than the idle mixture set screw, is there any other way to slow down the idle via fuel?
Large
Post by: thelews on May 06, 2009, 17:47:55
It's easy to set the timing at 3K plus.  Just rev the engine via the linkage while looking at the timing and make the adjustment to 30 degrees depending upon what you observe.  I have no helpers.  When the timing no longer advances as you rev, you've hit the limit of the mechanical advance and that is 30 degrees spec.  Your dwell meter has a tach also, so you can glance at your rpms, no?  Then you can recheck the 12-19 spec at 1500 and your idle spec with and without vacuum.  But, I would still defer to the high end spec.  Did you check the max advance when you were experiencing the 1500 rpm idle? The reason for the various specs is to verify the timing curve and that your distributor advance is functioning properly.
As Glenn suggests, if the timing specs at the various (especially max) rpms check out, then there's another issue affecting your idle speed.  You only gave us idle timing spec, so you have not ruled out timing as a possible issue.
I would still time with the vacuum disconnected, even though there is a spec for it connected, in order to rule out any issue that may be related to vacuum and be confident that the timing is correct.
Post by: waqas on May 06, 2009, 21:12:49
Are you suggesting one should set timing at 3000 rpm (30 degs) and then work backwards? Maybe I should try that.
My technical data book (issue 1969) gives the 230SL/250SE/250SL/280SE/280SL data for the IFUR 6 (0 231 116 051) distributor as:
(1) Adjusting value at 4500 rpm. without vacuum and without load: 30 degrees
(2) Inspection values during measurements with stroboscope:
Yesterday, after I replaced my points and set the dwell (closest I could get was 39 degs), I started to set the timing. As specified, I set the idle timing at 2-3 degs ATDC with vacuum. When I disconnected the vacuum line, the idle went up to 1100 rpm. I than raised the idle to 1500 and measured the timing as ~16 degs BTDC. However, the max advance I could get was 27 degs BTDC (at >3000 rpm).
Am I supposed to start from setting the max advance timing value and work my way back to measure the 1500 rpm and idle settings?
Post by: glenn on May 06, 2009, 21:47:26
Dear All,
Large
'idle mixture set screw'  --if you mean the  air screw on the manifold-- that's not how to reduce the idle rpm.  Idle gas flow is determined by the idle knob on the back of the FIP(fly weights), the CSV on the inlet manifold, atmospheric pressure on the lever inside the FIP, and the temperature compensation on the lever inside the FIP.  If the outside lever on the FIP has been rotated on the shaft from the factory setting, idle gas could be altered.  Adjust the FIP knob CCW to lower idle.  Then adjust the air screw to max rpm.  Repeat until rpm is 800, then cut til rpm is 750- i.e. 50 rpm rich.
Post by: thelews on May 06, 2009, 22:15:38
  • Starter speed and screwed-in spark plugs: 8 degrees BTDC w/o vacuum
  • Engine w/o load, idle speed, with and w/o vacuum advance: 2+/-1 degrees ATDC with vacuum
  • Engine w/o load, 1500 rpm, w/o vacuum advance: 12-19 degrees
  • Engine w/o load, 3000 rpm, w/o vacuum advance: 30 degrees
In answer to your question, that's how I do it, which doesn't necessarily make it right.
You will notice in your instructions, #1 says adjusting value 4500/30  #2 says inspection values and gives ranges for various rpms.  So, it seems that MB's priority is that you get proper and full advance above 3k rpm, which is where I spend much of my time.  The >3k rpm is a fixed amount whereas <3k rpm is a range.  So, once I've set the high value and confirmed the range values, I get a sense of how the engine is running.  I might just tweak the timing a degree or two and run the rpms up and down from idle to 4500 and see how smoothly the engine is running to and through the rpms.  I like to set it where things seem smoothest while still respecting the specs.  Then, of course, is the road test and how it feels under light load (surging? smooth? etc.), sharp demand (hesitation?  strong smooth pull? etc.) and how it feels at high rpm and speed (that nice effortless glass smooth feeling at 90 mph, yeah baby!).  I'm thinking one might find a timing that works best for their specific car that might differ slightly from spec due to gas, wear and interaction of other engine components.  Obviously, if you're way off spec, ve've got prrrrrroblems!
BTW, my distributor is a JFUR 051
Post by: waqas on May 06, 2009, 22:21:30
Thanks John. That makes sense now.
Post by: graphic66 on May 07, 2009, 01:31:51
What effect does the CSV on the manifold have on the idle speed?
Post by: glenn on May 07, 2009, 01:44:01
CSV(cold start valve) could stall the engine if it opens at 750rpm idle on a warmed up engine.  Probably speed up a cold starting engine with additional air coming in air passage on the temperature tower.
Post by: Largeowner on May 08, 2009, 08:16:50
OK,  I have removed the vacuum on the car and set the timing at 3000 rpm.  I ALSO could only get 27 degrees at 3000.  I took a chance and briefly reved to 4500 rpm, but 27 degrees seems to be the limit.  However, the 1500 rpm setting is bang-on and curiously enough, when I reattach the vacuum it retards about 14 degrees (as it should) to 2 degrees which agrees with the wiki.
In other words, the timing is just right.
In the above stated condition my idle in gear is 800 rpm, and 1100 rpm in neutral and idle.  I checked the adjustment at the venturi and the butterfly is fully closed in idle.
I adjusted the idle mixture knob 6 clicks toward lean (which was the limit of my bravery) and the figures remain unchanged.
Any suggestions?
Large
Post by: thelews on May 08, 2009, 12:12:26
Suggestions?  If the car is running great and the specs look good and the plugs read well with no pinging or knocking...leave it alone.
Why could you only get 27 at 3K?  Is the distributor stuck and won't turn any further or did you not try to advance it more?  If the distributor is stuck, or being limited from turning in some way, you may want to address that...you should be able to go past 30 and have a full range of movement.
You are not "taking a chance" revving the car to 4500 to check the advance mechanism.  The specs call for it and for the short period of a timing check there's no damage being done.
Post by: JimVillers on May 08, 2009, 13:08:51
Large ... Just to support what John said, if it runs good and you are happy, leave it alone.  On the other hand, you may not be driving with the engine RPM over 3K so you might not realize the benefits on a correctly tuned and running engine.
Tune the engine to how you like to drive.  I have a manual transmission and use the higher RPMs so I prefer my ignition set with more advance, similar to Johns.  But again, tune it to the way you like to drive.
Post by: Largeowner on May 08, 2009, 16:01:10
This thread started because I was experiencing pinging while hard-accelerating.  I am now satisfied with the timing on the car since the pinging is gone.  My only concern now is the 1100 rpm warm idle while in Park.  It results in quite a jolt when selecting a drive gear so I would like to decrease it.
My owners manual says to adjust the idle mixture no more than 3 clicks lean or rich of the factory setting.  I have no idea if the PO left this car at the factory setting, however, 6 clicks in the lean direction has not lowered the idle RPM a single bit!
I checked plug condition and gaps before I began this operation, and they showed a light formation of black soot rather than brown or tan.  My sense is that the car has been running a bit rich prior to my adjustments.
I am now contemplating adjusting the idle mixture progressively leaner until the idle is correct, or the car stalls due to fuel starvation.  Is there any reason I should not do this?
Large
Post by: Naj ✝︎ on May 08, 2009, 18:02:14
Have you tried the idle air screw behind the main radiator thermostat?
Its the big slotted spring loaded screw. Turn cw to reduce speed.
Post by: waqas on May 08, 2009, 18:12:18
The idle mixture is supposed to be a bit rich (perfect mixture is achieved in the mid-range RPMs, whilst high-range is also supposed to be a little rich).
Naj is correct, the air screw at the front end of the intake manifold should be able to reduce the idle air (and RPMs), but this will further enrichen the mixture at idle. This might end up being sufficient. However, before you reduce the fuel (via the injection pump; and correspondingly lean out the mid-range), perhaps you should measure the CO at idle? There is a spec somewhere here...
Post by: J. Huber on May 08, 2009, 19:13:16
A couple of probably obvious things. Its important to make sure the linkage is set so its not impeding your idle setting endeavors. Sometimes, the idle stop screw near air intake has been (incorrectly) used to adjust idle -- it essentially pushes on the linkage to add throttle. Make sure there is some space between this screw and the linkage stops.
Second, using the idle air mixture screw mentioned by Naj, you can use a vacuum gauge to establish the best idle speed to idle "sweetspot". With everything else (dwell, timing, plugs and linkage) all close, the idle should get you in the 750-900 range. Mine likes things a bit high -- when warm in gear is roughly 800. In park it raises to about 850-900.
Two helpful threads maybe my own travails here: (by the end we had it narrowed down to linkage -- and after my Dwell/Timing 101 lesson in another thread all has been very steady)
 http://www.sl113.org/forums/index.php?topic=6859.15
And also in the wiki, the ever-helpful "Basic Fuel Injection Linkage Adjustment and Idle Adjustment Procedures" under the fuel system link... everyone here should memorize this one...
Post by: Largeowner on May 08, 2009, 20:14:22
thanks guys,
I inspected the linkage last night and everthing seems ok there.  The idle stop screw appears to be alright.  The butterfly valve is fully closed at idle.
 Naj, could you post a photo of the idle air screw?
Since I have leaned the idle mixture 6 clicks, perhaps reducing air flow will enrich mixture to the correct point...time to find a co2 meter.
Large
Post by: Naj ✝︎ on May 08, 2009, 21:04:33
thanks guys,
Large
Blacklick idle mixture test:
After getting the idle speed adjusted, disconnect the operating rod at the throttle body and open the throttle flap to see how many extra revs you get. That will tell you how rich the idle mixture is.
Post by: ja17 on May 09, 2009, 03:35:56
Hello John L,
I was just looking at the photo of your distributor.  The cap is not quite correct. You may want to take a look at it since it is the later cap it may not be locked onto the ditributor and can move (rotate).  The early non-transistorized ignition distributor caps had a semi-circular cut out at the wire connection.  In addition these later caps did not lock onto the distributor like the early cap. No big deal and it may not cause any issues,  but I know how detailed you like to be. I can post some pics of the early an late caps if you like.
Post by: thelews on May 09, 2009, 03:46:21
Hello John L,
There is a very slight amount of movement in the cap on the distributor body when it is locked in place and yes, it could vary the timing ever so slightly.
I would appreciate a picture of the original cap (probably dark color) and even better, the Mercedes part number for the current comparable/correct replacement.
Thanks.
Post by: ja17 on May 11, 2009, 04:31:47
Hello John,
I double checked both caps and installed them on the different distributors.  They both lock on ok unless the mechanical attachment  parts of the non-transistorized distributor interfere with the transistorized cap which has no cut out. You are probably OK.
Here is the information on the caps anyway and here is a photo with MB numbers  of the two. Yes one is darker however I believe a lighter colored cap with the "cut out"  for the not transistorized ignitions was or is available.
Post by: thelews on May 11, 2009, 12:34:25
Thanks for the confirmation.
Post by: Benz Dr. on May 11, 2009, 23:34:49
The 051 distributor has two functions:
mechanical - 20 degrees of agavance
vacuum - 10 degrees of advance
The mechanical starts at about 1,000 RPM ( can be more or less 100 RPM and still be within specs ) and the vacuum starts as soon as you open the throttle. The vacuum portion will be all done around 1,500 RPM while the mechanical will continue up to about 2,700 - 3,000RPM The way the springs are adjusted plays into this as the tighter they're set the later the advance starts and ends.
If you have less than the full 30 degrees the only way to get more is by adjusting the pull rod on the vacuum cell. Turning it out will give you more movement and turning it in will give you less. You have to remove the cell to do any adjustments.
The mechanical advance is NOT adjustable but the rate of advance is. The whole distributor has to come apart to do that but small adjustments can be made by bending the arms in or out that hold the springs in place. There is no easy way to fine tune a distributor without a testing machine.
