W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Hath on January 21, 2009, 23:21:20
Title: Glove box fork and spring mechanism
Post by: Hath on January 21, 2009, 23:21:20
I was playing with the fork and spring mechanism that holds the glove box closed when the spring launched one of the forks into the desert (Arizona).  I've been searching but no luck.  Anyone know where to find replacements?
Title: Re: Glove box fork and spring mechanism
Post by: graphic66 on January 21, 2009, 23:26:34
I found some in the local hardware.They have a display full of springs.I found one I had to cut to length, but it worked.
Post by: Jonny B on January 21, 2009, 23:54:50
The spring is relatively easy, as already stated, the local hardware store can usually come up with something that will work nicely. The small forks are a different story. I have seem them on e-bay (as a set - two forks and a spring) but not very often. Did you check Gernold at SL Tech?? He usually can come up with some of the more rare parts. Will Samples in Texas (don't have his contact infor however) might also have one.
Post by: graphic66 on January 22, 2009, 03:01:03
OK I am off to my reading comprehension course, sorry I thought you lost a spring. How about a metal detector.
Post by: benzportland on January 22, 2009, 03:47:04
Bud's Benz (and I think several others) has the entire 3 piece kit for $28.00.
Post by: Hath on January 22, 2009, 17:39:21
Thanks to all.  Metal detector is a good idea.
Post by: mait on January 22, 2009, 17:49:43
How original do you want your SL to be? You have one fork left that can be used as a pattern. Make another if you have the materials and tools.
Post by: J. Huber on January 22, 2009, 18:20:22
While on the topic. How difficult (if even possible) would it be to reattach the metal "arm" back onto the box? Mine has been missing forever -- so I either lock the door or have it open.
Post by: scoot on January 25, 2009, 06:47:31
The forks and spring are available from the Classic Center.
Post by: Hath on January 26, 2009, 04:29:17
About 4 hours with a piece of aluminum and a dremel and I made the fork I needed.  Thanks for all the advice.
Post by: pagode.info on January 28, 2009, 09:07:52
The fork has the Mercedes-Benz part # 186 689 00 33
(available at any Merc dealer)
TOM
Post by: 66andBlue on July 30, 2010, 01:13:58
The spring that is currently sold by M-B is rather weak and tends to bend in the middle compromising the function of the opening and closing mechanism. While the door can still be opened and closed there is very little pull. First photo shows how this spring and the forks are supposed to work.
Mine gave up again today (3rd in 5 years) and I looked for a better solution rather then shelling out $15 again. Went to my favorite hardware store and found a brass tube by K&S with an OD of 7/16" (=11.1 mm) and an ID of 10.4 mm for $3.50. The spring fits perfectly into this tube.  I cut of a 49 mm long piece with a tube cutter which left a small inward bending rim. Put the spring in from one side,  then the forks and attached it to the box (2nd photo).  No more kinking!
I have enough tubing left to for 3 pieces , so drop a PM if you want one.
The tubing can also be bought here: http://www.hobbylinc.com/htm/k+s/k+s5137.htm
Post by: Peter van Es on July 30, 2010, 07:08:12
Since I have a limp spring also (need to lock the glove box) you might bring me a tube at the European Event. Clever solution.  Does it never move to the wrong end so that the door cannot be moved anymore?
Post by: Naj ✝︎ on July 30, 2010, 07:22:35
Free fitting included at Euro event?   ;D
Post by: gzmavian on July 30, 2010, 19:16:39
Hello to all concerned and perhaps confused members ( I'm apparently the confused member).  I have ordered the forks and spring from Dave Gallon and struggled to make the glovebox  door work correctly.  Based on the side view pictures, am I correct in presuming that the spring and forks should not have an angle and should function in straight alignment?  If this is the case, it explains the malfunction of my glove box door.  Thanks
Post by: Benz Dr. on July 31, 2010, 06:19:51
 They make a blue pill for this sort of problem Peter................
Post by: tel76 on July 31, 2010, 08:41:58
How do you know its blue, Doc?
Post by: mbzse on July 31, 2010, 14:33:02
Well, after all, he is a doctor isn't he...   ;)   True, a Mercedes doctor, but... they know pills...
BTW, the tube around the springs, it can be plastic, that works as well...
Also, I refer to this posting mentioning the glove box and its parts:
http://www.sl113.org/forums/index.php?topic=12912.0 (http://www.sl113.org/forums/index.php?topic=12912.0)
/Hans in Sweden
Post by: Atazman on July 31, 2010, 16:21:39
Posting this information has been a wealth of information.  Years ago, my arm broke loose from the door and "everything" went everywhere.  I had no idea what "everything" was supposed to be until I saw the pictures posted earlier.
I had saved the parts I could find, and now I know I'm missing only one of the little forks.  I have the other as a pattern so will make a duplicate.  Not sure yet how I will attach the arm to the door, but likely will be a dab of mig weld.
Thanks for posting the information and pictures.
Post by: gzmavian on July 31, 2010, 16:31:02
Well I visited my local hardware store to investigate the metal tube to use on the glovebox spring and forks.  I discovered that a rain gutter nail sleeve that fits around the long gutter nail works perfectly.  It is the correct inside diameter and is six inches long and, best of all,  costs 13 cents.  Who needs a little blue pill with a stiff six inch tube?
Post by: 66andBlue on July 31, 2010, 17:04:54
... Does it never move to the wrong end so that the door cannot be moved anymore? ...
Peter,
that is why I used the tube cutter since it creates a restriction that prevents the tube from moving down. Might help to crimp it even a bit more.
zav,
thanks for finding this cheap "generic" ... and you don't need to color it blue.   ;)
But make sure that you crimp the top. If the tube slides down and wedges between the arm and the box you may be in for trouble.
Post by: 66andBlue on July 31, 2010, 17:12:19
....  Not sure yet how I will attach the arm to the door, but likely will be a dab of mig weld.  ...
Atazman,
here are some dimensions that might be useful for your welding job. Just make sure you do not change the convex contour of the door somehow.
Post by: Atazman on July 31, 2010, 23:56:52
I lucked out.  Without having your measurements, 66andblue, I went ahead and tack welded the arm to the door. Just "sized" things up to make sure the door would open all the way, and close without the arm binding up. Then..... tack welded in three spots around the arm, with cooling time in between tacks.  Also, I had a wet rag against the front of my door to keep the heat from melting my paint.
Fabricating a new fork to replace my missing fork was easy.  I had scrap metal that measured within 0.001" of the thickness of the original fork.
And my luck continued........ I had a section of copper tubing that appeared to be close in size.  Stuffed the spring inside the tubing and it was a great fit.  Cut the tubing to just under 2", greased up the spring and forks, assembled everything inside the copper tube............and I'm back in business.
Thank to all..............
Post by: 66andBlue on August 01, 2010, 04:17:07
Well done!
Do you accept orders?  ;)
Post by: Peter van Es on August 01, 2010, 08:59:31
Excellent stuff (esp the pictures) for the Technical Manual!
Post by: gzmavian on August 01, 2010, 23:44:48
Well, this is a follow up on completion of the glovebox spring tube project.  It works perfectly !  Alfred, great engineering intuition.  A simple solution  to a frustration problem.   Thanks,  Greg
Post by: Anfinn on August 06, 2010, 18:23:59
Alternative source for the tube:
IKEA floorlamp. I,m sure no-one at home will discover that I chopped 50 mm off the top of the lamp in the den. ;D
Post by: tuultyme on August 13, 2010, 17:25:35
I found a spring at Ace Hardware that was of the correct size; length and diameter but was stronger (thicker material).  This has worked great without the extra sleeve.
Post by: tel76 on September 06, 2010, 20:28:48
Hello Alfred,
Where the door lever (the half moon item) goes through the glove box is there a piece of metal to tidy up the hole in the covering material? A photograph of the glove box with the door open and fitted would help with this query.
Post by: 66andBlue on September 06, 2010, 21:31:17
Hi Eric,
yes there is, but NLA.  A member of the German group sells excellent reproductions should you need one:
http://www.pagodentreff.de/diskussionsforum/t7274-rosette-handschuhfach.html
Post by: Garry on September 07, 2010, 06:41:32
I also bought one from Dave Gallon last year so he may still have some
Post by: tel76 on September 07, 2010, 08:28:16
Alfred,
Can you interperate the information on the site you mention,how much do they want and what is the address/ phone #?
On your photograph there appears to be two rubber buffers at the top left and right side (i have two holes only)is there any screws behind the buffers an d do you have the part # of the buffers
Post by: 66andBlue on September 07, 2010, 16:16:11
Hi Eric,
sent you a PM with the ordering info.
I do not have the original p/n for the two rubber buffers but I do know that MB lists a replacement p/n. However, don't buy them, they will not fit properly! They are too thick and the door shows a gap.
Post by: jacovdw on September 10, 2010, 10:19:31
Hello Alfred,
Would you be so kind as to send the ordering info to me too via PM please.
I'm also missing that little metal trim ring on my pagoda (compliments of the PO...   >:( )
Thanks in advance.
