W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: john.mancini on January 08, 2009, 23:49:33
Title: wheels
Post by: john.mancini on January 08, 2009, 23:49:33
Wheels question?
I purchased a set of wheels that have the part number 108 400 00 02. They are date coded 11/66. The tech manual suggests that these wheels replaced the 113 400 00 06 for the 230SL. Am I correct in assuming that the 108 wheels are factory correct for a 230SL - 250SL?
Many Thanks,
Title: Re: wheels
Post by: 66andBlue on January 09, 2009, 01:22:17
108 wheels are correct for a 230SL after VIN 005498, "with the exception of 005500, 5502, 5505, 5506, 5510, 5513 and 5521".
You should be fine unless yours is one of those exceptions.
Title: Re: wheels
Post by: john.mancini on January 09, 2009, 02:52:58
Thank you 66andBlue.
Title: Re: wheels
Post by: ja17 on January 10, 2009, 04:05:15
Hello John,
I show the correct W108 wheel as #108 400 00 02.  Chect to see if the wheels you got has the stampings to recieve the small hub caps.
The W108 V-8 wheels were 1/2" wider (6 1/2") and did not have any provision to accept the smal hub caps. Not sure what these were numbered.
Title: Re: wheels
Post by: john.mancini on January 11, 2009, 03:06:54
Hello Joe,
The wheels are stamped 6Jx14H, dated 11/66 and have the stampings for the small hubcaps. When I bought the wheels I was told they were for a 280SL. I guess they are really for a late 230SL and 250SL's.
Title: Re: wheels
Post by: ja17 on January 11, 2009, 03:35:52
Thanks John,
These seem to be another correct version, I am adding the new number  to my data.
