W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Fonzi on October 15, 2021, 17:20:41
I am trying to learn and understand the r20y injection pumps (from 1969 280se) I have here, and would like to understand what the top solenoid (Bosch 0330101012 ) and bottom solenoid ( Bosch 0330101013 ) are supposed to do.
The pump that was in the parts car with good compression seems to have a bad check valve on cyl 4 but I wonder if it has other issues as I note the solenoids have definitely been off and make even broken. See the bottom solenoid in the background of the picture.
Top solenoid is for fuel enrichment in the FIP. I pushest the rack forward. It always engages when starting the car cold or hot.
The bottom is called the fuel cut off solenoid. It is engaged by a micro switches on the firewall and transmission when at idle and 3 or 4th gear I believe. In don’t remember exactly. It was designed to cut down on air pollution.
You can read about it more in the tech manual.
Thank you! So I should get 12v to the top one when cranking. Should 12v continue after I let off the starter?
I’m thinking I should leave the bottom disconnected when trying to get an old motor running. Eh?
Yes. You should get 12v on top solenoid only when cranking.
Some people disconnect none, one, or both depending on their particular issue.
Thank you!
Just curious, after cranking, what handles the enrichment while the car is warming up? Is there a wax bulb up top that somehow affects the amount of fuel that goes to the injectors?
Correct. Do a search on “WRD” or Warm Running Device. Check out the tech manual. All the answers are there👍👍
