W113 Pagoda SL Group => General Discussion => Topic started by: John Betsch - "SADIE" on November 28, 2018, 19:40:44
Just purchased a set of wood trim from the Classic Center. for a 65 230sl The radio Grill Cover came with two pre-drilled screw holes. My present trim does not have any visible screws. I would expect the Classic Center to be correct but is it?
JB
Yes. There are supposed to be 2 screws that fasten the wood speaker grill to the dash.
Well, no for the 230. Instead two pins that goes to clips in the dash. See https://www.sl113.org/forums/uploaded/sjiatrou/2007210203042_SpeakerGrill.jpg
and https://www.sl113.org/forums/index.php?topic=6514.msg40646#msg40646
Oops. I did not know there was a difference. Thanks for the catch.
Some photos of mine,may also help. just did them a month ago, regards.
2 photos. 2 recessed screws one at each end.
interesting
my 66 230 has the 2 screws...
My 1965 230 SL has the pins.
The cutoff between pins and screws in the speaker grill was made in beginning of November 1965 from VIN #14090, according to Pagoda Notes Vol. 10 No. 2.
