W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Pinder on December 04, 2020, 17:45:23
my 280SL at some point prior owner had sprayed on black underseal of some sort. Its not very thick and I am able to rub it off with some effort with gasoline or Laquer thiner. The not seem to affect the factory undercoat which is some kind of light color. I am trying to remove this black underseal and leave the original intact. Any other recommend ways of removing the black undercoat that would be quicker and also safe on the original?
I have heard people removing the undercoat with dry ice. Plenty of videos on YouTube.
I have no idea how safe it is for our cars.
Tom Collit used to swear by the dry ice method of removing it but not the paint and i am sure there are posts here on its use.
https://www.sl113.org/forums/index.php?topic=23838.msg170556#msg170556 (https://www.sl113.org/forums/index.php?topic=23838.msg170556#msg170556)
I have detailed several undercarriages mainly using low odor mineral spirits.
Takes some time but if you want to do it yourself, it works.
I tried mineral spirits but maybe i should let it sit longer. So far lacquer thinner is working but its pretty strong and does affect the original underseal if you work an area too long.
I had a company use dry ice to do my undercarriage. I had to find someone with an outdoor lift that I could use so they could get underneath. I was reasonably happy with the results. In my case there was thick undercoating to remove, plus years of dirt and grime.
But doesnt the dry ice affect the original coating ? I am trying not to disturb the original coating which is intact and there is no rust (that I am aware of).
I am curious what company does this dry ice cleaning?
Anyone in the Philadelphia area?
JN
