W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Classic_Cars_Dubai on April 26, 2019, 03:53:54
Hey Guys
Looking for a bit of advice on a where the Rotor Arm should be pointing where the engine is TDC. The MB is a correct 280SL with an 051 Distributor with Vacuum retard and currently pointing nearer to the 4 o'clock position when i get it to TDC and I have read it should be 2 o'clock.(When i reference the clock # position, I would be standing in front of the car and 12 is obviously facing the windshield). The car is running and will start up, but seems to have a small piston misfire after it warms up.
I cannot find a picture to reference, so would anyone have one?
Do you have a timing light? You should set your timing to around 8 degrees BTDC at idle and should have around 38 degrees BTDC at full advance with vacuum connected.
When you remove the distributor cap and look at the edge of the aluminum housing, you will see a mark on this edge, a small cut. That is where the rotor should be pointing (more or less). When you set it there, check if you are on TDC cylinder 1 (just in case) - try to look through oil filler opening in valve cover to see if both cams on cylinder 1 are up, meaning both valves are closed. Then also the mark on the pulley that you use for setting the ignition timing should be somewhere around 0 (give or take 10 degrees).
You see the mark on the picture next to condenser (it may not always be next to condenser!). It may be bigger cut or smaller - depending on the distributor.
What you can also do is to follow the ignition lead from spark plug in cylinder 1 to the distributor cap - it will go to one of the connectors in the cap. The rotor in TDC for cylinder 1 should point to that connector for lead from spark plug in cylinder 1 (when the cap sits on the housing with its lip in the slot for it in the housing).
I had to re-orientate my distributor as you suggest.
I moved the distributor so that the rotor arm pointed to the mark when No1 is at TDC as shown by Pawel. Then I had to move my plug leads around to make sure No1 lead was also synchronised with this position.
Then I set the timing up as Joe described. Just a slight tweak was required.
i am not saying whether 2 o'clock or 4 o'clock is right for you as my car is a 220se.
