with our official
Pagoda SL Group logo
from our official partner.
When were ball check valves introduced on the injection pumps?
Topic: When were ball check valves introduced on the injection pumps? (Read 2728 times)
rgafitanu@gmail.com
October 20, 2017, 20:10:30 »
I have the opportunity to get a defective injection pump to use for parts. I am interested in the ball valves. There are 2 pumps available, a R20 and a R24Y. Anybody knows which one came with the ball check valves?
Thank you
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Re: When were ball check valves introduced on the injection pumps?
October 21, 2017, 15:09:40 »
The r24 is a later pump. It does have the ball type check valves, but they will not fit into an r-18 or r-20 pump without machining work. Some later r-20 pumps did have the ball type valves.
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #2 on:
October 21, 2017, 15:33:35 »
Maybe it will help: in the BBB you have the IP listed with modifications that were made. Just had a BBB at hand, see below if possible.
rgafitanu@gmail.com
Reply #3 on:
October 22, 2017, 01:34:22 »
Thank you Tyler and Pawel, I have the BBB book but it doesn’t mention when ‘the ball check valves were introduced. I have access to a lathe to machine them. Are they longer or wider? What do I need to machine?
Associate Member
Platinum
USA, OH, Cleveland Heights
Reply #4 on:
October 24, 2017, 02:06:17 »
I believe the "Y" designation denotes ball valves.
Full Member
Platinum
USA, CA, Solana Beach
Reply #5 on:
October 24, 2017, 03:52:06 »
The "Y" indicates the USA versions of the various injection pumps. See the list here:
https://www.sl113.org/wiki/Fuel/Injection
It appears that the ball valves were introduced with the R21 and R22Y pumps.
Thus, to answer Radu's original question: the R20 pump does not have the ball valves.
There is now also a parts list for download in the Tech Manual.
{Crossed out statement about R20 IP, in light of A. Dalton's later post}
Last Edit: October 24, 2017, 18:33:33 by 66andBlue
1966 230SL automatic 334G light blue (
sold
Reply #6 on:
October 24, 2017, 13:28:29 »
Late R18 were upgraded from cone to ball valves [ R18z / 250sl]
R20 pumps had ball.
R22 the balls size was increased to 4mm.
R24 is the replacement and they retained the larger balls [ 4mm]
rgafitanu@gmail.com
Reply #7 on:
October 24, 2017, 16:29:43 »
Thank you, I am assuming that the 4mm ball valves will need machining.
Associate Member
Platinum
Reply #8 on:
October 25, 2017, 02:14:17 »
Pretty easy machining. just a cut in diameter. 15 minutes apiece max.
