Author Topic: 250 SL seat adjustment knob removal.  (Read 2931 times)
swood1
  • United Kingdom, England, Worcester
« on: October 22, 2016, 12:47:32 »
Hi all,
Can anyone advise on how to remove the black seat adjustment knob as per photo attached?
Steven
250 SL (early), in bits. Triumph TR4a
cfm65@me.com
  • Mossel Bay, South Africa
Re: 250 SL seat adjustment knob removal.
« Reply #1 on: October 22, 2016, 13:47:56 »
Hi Steven,
There is a hole in the back to pop the cover.  The wheel is then held in position by a large phillips screw if I remember correctly.  I have rounded the sharp end of an old phillips screw driver, then gave it a 90* bend about an inch or so from the rounded end. Find the hole in the back, I think there might be two, stick the 90 degree bend into the hole and pop the cover off.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Pinder
  • USA, NJ, Edison
« Reply #2 on: October 22, 2016, 13:52:14 »
you can also use an allen key to get behind the knob and push through the hole. I think there are two holes so you can push it out evenly.
swood1
« Reply #3 on: October 22, 2016, 14:14:04 »
Thanks guys.
Shall give it a go.
swood1
« Reply #4 on: October 23, 2016, 18:55:19 »
All sorted now.  Tapped it off with an old screwdriver with a broken tip.
Cheers
Steve
