Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
Unknown Relay R/H Engine compartment
Topic: Unknown Relay R/H Engine compartment (Read 3529 times)
CJHenderson
Full Member
Silver
USA, AR, Benton
April 28, 2016, 18:37:24 »
Have a relay on the right side of engine compartment just aft of the shock cover. Looked in Chilton manual cannot locate it.
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Vendor
Platinum
United Kingdom, England, Richmond
Re: Unknown Relay R/H Engine compartment
April 28, 2016, 18:55:02 »
Voltage regulator
Stick
www.colinferns.com
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #2 on:
April 28, 2016, 19:03:00 »
Great thanks
1950 MG-TD
Associate Member
Gold
USA, West Seattle, WA
'69 280SL,Signal Red,
Reply #3 on:
April 28, 2016, 23:47:48 »
I found when I checked the voltage with the alternator turning, it would read 12 volts. It should read about 13.8 volts. So I opened it up and turned the little screw until it read 13.8 volts. I wonder why my battery is now happier.
'69 280SL,Signal Red, 09 cam, License BB-59U
'67 230SL, 113042-10-017463 (sld)
'50 Jaguar Roadster XK120, #670.318 (sld)
tired engineer, West-Seattle,WA
awolff280sl
Full Member
Gold
USA, FL, Sarasota
Reply #4 on:
May 01, 2016, 11:17:45 »
I was not aware that the output voltage is adjustable.
Where is this little screw located?
Andy Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Reply #5 on:
May 01, 2016, 15:04:46 »
Andy, If you remove the top cover you will see the adjustment. Cleaning the contacts often helps as well. Only the Original regulators have this adjustment. The replacement ones are not adjustable.
