Author Topic: spin on oil filter  (Read 14640 times)
spin on oil filter
« on: March 29, 2015, 02:59:18 »
A spin on oil filter has been discussed in the past.  Anyone know if this ever did make to production?
Re: spin on oil filter
« Reply #1 on: March 29, 2015, 04:06:32 »
Hello JP,
Check with the 190SL group.  I think the same unit is used.
awolff280sl
  • USA, FL, Sarasota
« Reply #2 on: March 29, 2015, 13:34:27 »
I have been using it for several years and like it alot. Got it through Jim Villers at the 190SL group.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
« Reply #3 on: March 29, 2015, 21:03:19 »
Great!!  Thanks guys.
« Reply #4 on: March 29, 2015, 21:29:24 »
I sent Jim a PM and noticed he has not visited this site in almost a month.
I took a look at the 190sl store items and found the item. There are two choices.  Deep well socket or No socket.
Which one do I order?
Thx
awolff280sl
  • USA, FL, Sarasota
« Reply #5 on: March 29, 2015, 23:46:13 »
I can't say which one, Jim advised me. Install does involve the use of a deep socket, if that's any help.
You will need a short spin on filter, I use WIX 51348, and a good strap wrench that fit in that tight area.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
mnahon
  • Canada, QC, Montreal
« Reply #6 on: March 30, 2015, 02:31:03 »
In the description, it says " Installing an adapter requires a 15/16 inch or 24mm deep well socket. "
Looks like the choice you get when ordering is if you need to also order the socket or not.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
GGR
  • USA, DC, Washington
« Reply #7 on: March 30, 2015, 18:58:21 »
What is the advantage of a spin on filter over the stock one?
Raymond
  • USA, FL, JACKSONVILLE
    • GemstoneMediaInc.com
« Reply #8 on: March 30, 2015, 23:47:08 »
I am quite happy to have made this upgrade.  I believe the difference is with one you are buying the adapter kit only and the other comes with the socket.  I have the socket and you are welcome to borrow it.
I have the adapter on my car and I love it.  For one, it uses newer technology filters that do a better job of filtering.  That said, it probably won't make a bit of difference over the life of the car unless you drive in really dusty conditions.  It is quicker and easier to change a spin on filter and you don't have to worry about the inner seals.  I use K&N or Mobil1 205 filters.  They are exactly the same filter my BMW E30 and VW Cabrio use so I have only one size on the shelf.  (Not counting the Nissan)  You can get them everywhere.  On frequent sale at Advance Auto Parts you can get 5 quarts of synthetic oil WITH an oil filter for $34.
For the installation on our cars, the center thread tube is a bit long.  You'll want to cut about 30mm off and file the end of the thread.  Other than that, installation is a breeze.  You can use the full length of the center thread, but then you have to use the 208 style filter that doesn't have the center pressure relief bypass valve.  That's not a problem if you keep your oil clean.  It just means that you spend an extra minute or so spinning the filter on and on and on... and then off, and off, and off.  It also means that at the far end of the thread, the filter is hitting the motor mount.
