Author Topic: Wiring diagram for an early 280SL Automatic gearbox  (Read 3679 times)
Quin
« on: August 29, 2014, 11:51:57 »
When starting rebuilding my 280SL Automatic , I have taken out all the not original wires which were added all around ( to fuel pump , to coldstart valve and low temp sensor , to injection pump ) ,under the dashboard and in the motor compartment.
To rebuild and to re-connect all wires as original as possible , I'm looking for a wiring diagram  280SL with automatic gearbox .
thanks already in advance
Re: Wiring diagram for an early 280SL Automatic gearbox
« Reply #1 on: August 29, 2014, 12:06:38 »
If you look in the Tech Manual there are wiring diagrams for all the cars available to Fumm Members..  :o
http://www.sl113.org/wiki/Electrical/WiringDiagram
Using the search function, click on the Tech Manual then do the search on the left hand side for anything you need.  As a Full Member, you have total access to all parts of the Forum and Manual
1965 MB 230SL Auto RHD Lt Blue 334G, Top 350H, 213 Leather, Tourist Delivery.
1972 MB 280CE Auto RHD 906G Blue Grey
2005 MB A200.
2019 Izuzu DMax 4x4 with Slide-on camper.
2022 Volvo XC40 Twin Electric
Quin
« Reply #2 on: August 31, 2014, 11:07:18 »
Thanks for the tip .
Indeed found back lot of information and I already could reconnect the fuel pump , the cold start relais and valve  .. I still some things to search and refurbish and with little bit of luck I will be able to start the engine end next weeK .  :)
« Reply #3 on: August 31, 2014, 11:41:52 »
And if you have any problems just ask the questions and I am sure members will jump in and try to answer them so that your Pagoda is back on the road.
Good luck with the engine start up.
2005 MB A200.
