Welcome, Guest. Please login or register.
Did you miss your activation email?
  Home    Forum    Technical Manual    Help    Search    Login    Register
News : Need to know something? Search the Technical Manual first, then Search the Forum. Post a question last! March 28, 2015, 10:19:37
Pagoda SL Group  |  W113 Pagoda SL Group  |  Wanted To Buy  |  Topic: WTB: Injection pump thermostat for 230SL Advanced search
  « previous next »
Pages 1
Locked Topic Topic: WTB: Injection pump thermostat for 230SL  (Read 5465 times)
« on: March 07, 2013, 18:51:18 »
Sleeping Beauty
Need a functional thermostat for R-11 pump.  Also known as Warm Running Device (WRD)
Thanks,  Brian
Reply #1
« on: March 08, 2013, 05:13:53 »
IXLR8
Full Member
Silver
Hi Brian--
You will see them frequently on EBay. They sell for around $46.
Look under W113 parts or 230 SL parts.
I haven't looked today, but there was one listed within the past week.
the other Joe
113 042 10-010467
Reply #2
« on: March 08, 2013, 07:08:33 »
Sleeping Beauty
Well, yes there is a current listing for $850 Shocked     http://www.ebay.com/itm/MERCEDES-230SL-250SL-300-600-FUEL-INJECTION-CHOKE-THERMOSTAT-WARM-UP-INJECTION-/130852718961?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e776e0971&vxp=mtr
I was hoping to find a working used one for less.
Reply #3
« on: March 08, 2013, 07:28:08 »
Membership Administrator
Platinum
'65 230SL Location: Australia, Victoria, Hanging Rock
WWW
surely that $850 cannot be right?Huh?
Hanging Rock, close to Melbourne, Australia
1965 MB 230SL Auto RHD Lt Blue 334G, Top 350H, 213 Leather, Tourist Delivery
1974 VW Kombi Pop Top Camper
2013 VW 180 V6 Touareg
Reply #4
« on: March 08, 2013, 13:45:44 »
w113dude
Inactive
Gold
would you be able to use this instead?
Shaun Pooladian
67 250SL Auto late, Euro under restoration
70 280SE Coupe factory 5speed
72 250C  (for sale)
80 300CD, converted to 4sp manual, every day driver
Reply #5
« on: March 08, 2013, 17:00:36 »
Sleeping Beauty
Shaun:
I'm not sure if that's a fit.  Mine is in the shop at the moment...so I can't confirm till Monday.
What year/model did yours come from?  Later than 1966 won't work.
Thanks very much,
--Brian
Reply #6
« on: March 08, 2013, 17:07:34 »
Full Member
Platinum
The WRD for the 230 SL is/was quite expensive. A different beastie than on the later pumps.
Reply #7
« on: March 08, 2013, 19:01:39 »
w113dude
Inactive
Gold
No, it actually came out of a late 67.
Shaun Pooladian
72 250C  (for sale)
Reply #8
« on: January 10, 2014, 16:44:28 »
Paul99
Associate Member
Senior
I have found out that there are two, a long wax stat, only on the early 230's and the short wax stat after 67ish I think.  Anyway, totally different, not mixable as the housing etc are 100% different.
The long (early 230 wax stats) are like hens teeth!  about $800 or more the later smaller wax stats are really cheap.  But you can swop the whole assembly - wax stat and housing and WRD at a total unit which may be a way around the $800 buy!
I have been looking at this issue for a long time, I thought my wax stat (the $800 one )was duff, but in fact its fine.  Putting in hot water and the end moving by a few mm's is fine.   (about 4 I think)  The issues seem to all be around the plunger getting stuck.
One question though - should there be any kind of washer between the wax stat (the long one) and the housing? Otherwise its just brass on aluminium ?
Reply #9
« on: January 11, 2014, 01:41:41 »
Full Member
Platinum
.. One question though - should there be any kind of washer between the wax stat (the long one) and the housing? Otherwise its just brass on aluminium ?
Yes. See this photo in an earlier post:
1966 230SL automatic 334G light blue
Reply #10
« on: January 11, 2014, 18:39:55 »
George Des
Associate Member
Gold
I sold a good used one not too long ago on ebay. They are different from the ones used on 280sl. Not sure about the 250Sl FI pump but othfr pre-67 FI sedans used the same wax filled thermostat. Not sure if the entire newer type assembly can be adapted to work with the R11 pump
Reply #11
« on: January 17, 2014, 12:15:03 »
twistedtree
Associate Member
Silver
I'm pretty sure the various WRD assemblies are NOT interchangeable.  I recall trying this a while back and the bore in the injection pump body is a different size for the different WRDs, You either can't inset the wrong WRD, or it will be loose and flopping around.  It's been a year or two since I played with this, but that's my recollection.
Oh, and I think there are three different assemblies, though only two different wax heat feelers.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
1971 Volvo 142E
2011 BMW 550xi
Reply #12
« on: January 18, 2014, 16:20:49 »
George Des
Associate Member
Gold
This is certainly a part that Bosch or MB should consider for manufacturing again if NLA. It is an essential part of the FI pump and I'm not aware of any work arounds if a replacement can not be found. All that being said, I'm not sure that the part is one that needs to be replaced that often given that all it appears to be is a wax filled cylinder with a small piston like actuator pin, but if you need one, you need one!
George
Reply #13
« on: January 18, 2014, 18:03:20 »
m300cab
Associate Member
Senior
I'm an investement advisor, been watching the imaging and reproduction sector, one company is 3D systems, I imagine they can reproduce the part, or their competitors...(xone)
anyone have time to research this?
Michael Parlato
Reply #14
« on: March 07, 2014, 21:45:15 »
Travis71280
Full Member
Regular
Shaun are you selling that wrd? I have a 1971 280sl in need of one. The air valve on mine froze up and it looks just like that one. I was just curious...
1970 Chevrolet C-10
Print  Pages 1
Pagoda SL Group  |  W113 Pagoda SL Group  |  Wanted To Buy  |  Topic: WTB: Injection pump thermostat for 230SL « previous next »
Jump to:
