W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Reischmann on January 22, 2013, 13:05:30
When I removed the tach and center instrument cluster I found a momentary on switch (0343105008), attached to the factory harness, just sitting there.
Anybody know what it is and where it goes?
Also, the dash lights will not dim, using the dimmer control?
Thank you,
Mike
I have never seen any switches behind the cluster, most likely this is the switch that was added to by-pass dimmer.
Thanks for the quick reply.
It is a spring loaded, normally open, micro switch.
It looks factory.
Did you see the picture attached to the original email?
Mike
What Shaun has already mentioned...
There _is_ no additional switch behind the cluster from factory. :o Yours is clearly an aftermarket and a shade-tree mechanic solution. 8)
It is very common that the dimmer rheostat for the dash light deteriorates when aged. This is especially true if it was not used in the past (dimming around to prevent corrosion).
As a solution a by-pass bridge is very common - as Shaun already said.
The rheostat is NLA and I do not know of a suitable replacement.
Maybe one of a /8 or even a W110 fits but I have not tried yet.
Mike, something doesn't make sense here. Shaun and Achim are surely correct in concluding that the switch is an improvisation; beyond the fact that they both know their stuff, the part number is nowhere near an M-B number, much less one contemporary with our cars. And plugging something in at that point would be a tidy bypass/shunt/jumper - - except that you seem certain that the switch is a normally-open momentary type, which couldn't possibly serve in that capacity. So just to be clear: you've tested the switch and are certain of its function? [If it were actually the opposite -- normally closed -- of course that would make it a workable fix, and I have seen some that were convertible though that one doesn't look like it.]
Certainly is a puzzle as to why such a thing was chosen, and even more, how your dash lights could function at all with the circuit normally-open at that point. Maybe it's a problem with terminology: electricity-speak for a switch that passes current through is to refer to it as closed, and an open anything -- switch or entire circuit -- will not allow current through because there is an open gap there, so no path for the current to follow. It's like taking out a section of railroad track or blowing a bridge, not like shutting a valve.
We have excellent circuit diagrams in our Tech Manual section which are accessible to full members. [Most of the TM is open to all but some of the best stuff requires joining up.]
Welcome. And when you get around to it, being a full member costs something on the order of 10 cents a day; absolutely the best bargain I know of.
Can we see the picture of the switch or is it a secret?
Richard M, NYC
Thanks Richard,
There is an attachment, with a picture of the switch plugged into the harness, just as I found it, at the bottom of my original email.
Mike
I beleive this momentary, normally open switch, is part of some other assembly. The dash lights work, with or without the switch in place.
I will continue to check the functionality of the other controls and let everyone know what I find.
Thank you,
Mike
Hi Mike,
If you follow the two wires from the micro-switch it's most probably going to the connector under the dash, then check to see which wires they are connected to from your wiring diagram. I'm curios to know what it is too.
Hmmm a puzzle allright.
Do your wind screen washers work - they use a momentary type switch. If the phantom switch, at one time could hang down below the dash, could it be a work round for a broken washer switch, or something in the engine start that needed a fix for starting?
If the switch was never accessible, then it really is one of lifes mysteries.
Good hunting
